Hey Guys i have a 2011 650R and recently bought a Arrow slip on.
To my surprise there was no gasket included in the package :(
i bought a OEM Kawasaki gasket but theres just no way that its gonna fit. theres only about 1mm play when the slip on is attached, and the gasket is about 3-4mm thick.
Is there another gasket that i was supposed to buy? or is there some other alternative?
Cheers,
Dom.
Don't know, I didn't use a gasket. The clamp design looked to me like it didn't call for one. No leeks yet.
No gasket required bro
Thanks for the replys guys, will try it out.
Also, have found that riding without the silencer in is quite deafening.
Having the silencer in it sounds similar to stock.
has anyone made a custom silencer? or modified the supplied silencer?
I've never seen the 2bros silencer, but i modded my DanMoto silencer.
The end you can't see is solid. I drilled 1 single 1/4in hole in it, and it made a significant difference in sound. So, just an FYI... a small mod, can make a sizeable difference. May have been the fact that the hole is "straight through" instead of being on the side aimed at the noise absorbing material.
