Currently having issues where the bike would just turn off on idle or while riding. Thinking it could be the fuel pump because sometimes it sounds weird at start.
Then today i updated the power commander firmware and.... Magic smoke came out.......
Well i have to remove it and figure out why it burned up.
I'm still going to replace the fuel pump and clean the injectors. Meanwhile i do that I'll install the airbox and the air inject exhaust valve thing. So it's going to have a good amount of downtime.
Also added 100ohm resistor for the KOSO gauge since you can only select 100ohm or 250 and as far as I know the 2009 ER-6N is 204-210 ohms on empty. Edit: wait a minute, it's supposed to be 5-7 ohms on full.... Woops gotta undo it
