sounds similar to when a rider gets headshake, then the front brakes wont work until you pump them a bit.
I wonder if your pads/calipers are coming away from the disc while its sitting, so you need to pump it to get them back in contact.
Like arturo said, put it on the rear stand after its been sitting for a while, and see if there is a lot of seperation from the rotor. They should be almost (if not) touching the rotor.
