1 - 2 of 2 Posts
The squeak could be just because the pads are new.They need a bit to break in.It could also be the backing plates on the pads.You could put some anti-squeal shit on the back of the pads.Probably just need some use though.The chain should have about an inch of slack.I'm generally quite fond of things being tight.Except my chain.Measure the chain slack halfway between the sprockets on the bottom.You should be able to push it up half inch and down half inch.Good luck at the drags.
What could be the prob? I put on a new rotor and new brake pads, could it be that i didnt itghten or too tightened them? ALso how tight is the chain supposed to be? I just got new tires and that mofo is tighter then virgin! shit
thanks for the help brothers! i'm taking the 95' zx6r to the local drag friday will post results!
1 - 2 of 2 Posts
