Yes im on the right forum. Im in the offroad and atv section. A bayou is a four wheeler made by kawasaki and how do i get the axle out of front diff? Ive seen it done amd try seperating it and tapping around edges with a pry bar but i cant get it to pop out of differential
The Indifference Engine
You grab it and give a couple sharp tugs. Only one side of the shaft can be dissassembled, and it should have a circlip. The other side pulls across the length of it.
Powerhungry
if it just slides into the diff, then you need pry it out.
using a larger screwdriver, or pry bar.
or even a large chisel, but used in such a way that is slides between the axle and the diff, to separate it.
usually popping it quickly is more affective than a continuous push.
if that makes sense.
