O.K.. I got some pictures to show all of you. I will give a brief description, but if you need more, let me know..
The fisrt 2 pictures are of the mounting location for the display. I know that a lot of people mount it close to the handle bars (because of the circulay mounting bracket) but honestly, you can't see it there. I used some tie straps (I love those things) and secured it to the front of the bracket attaching the gauges.
This picture shows the attachment of the magmet to the brake disc. As you can see, you need to cut away the plastic holder, and take out the long-skinny magnet which you will find inside. This position takes into account the brake itself, and insures it will not get lodged inside the brake. I used a tie strap to secure the magnet because I didn't want to fuss with glues/bond.
This picture shows the magnet sensor wire which is housed inside of the fork fender. It really doesn't matter how nice the install is because it will be covered by the cover anyhow. Tie straps used again.
This is showing the sensor mounted on the inside portion of the fork. As you can see, the sensor is at an angle so when the magmet passes, the two will not hit eachother.
This last picture shows the magnet and the sensor when they pass eachother. As you can see, the magnet does have to pass pretty much parallel to the sensor but there is a small amount of space between the two when they pass.
Hope these help.. As far as the install, that is the easy part. It is harder to measure your tire, and test it.
Good Luck.
