Sooo...I put a set of Big Piston forks on the 2006...no pics, but I can add them later.
These are not that much lighter than stockers...just half a pound each...making them about the same weight as the ZX10R forks I put on my zx7r project. My goal on the swap was more of a handling improvement anyway....and to see if I could do it.
Here's a summary.
- The front end I aquired didn't include an upper triple clamp. So I took my stock upper clamp and bored it out the extra 1mm...so yes, that means the fork offset and spacing is identical.
- took my vortex clip ons and did the same thing....having machine shop access has advantages.
- I had to swap the steering stems since the 05-06 stem is ~3/8" shorter.
- bearings, spanner nuts, seals are all the same.
- the steering stop of the 09 lower triple works perfect.
- wheel with 2005/6 spacers goes right on.
- you'll need a 2009+ fender as the moved the mounting points.
- your old brakes will go on....or get newer Nissin's.
- the springs are .95kg/mm...which is great for my weight.
- I don't know if the 2009+ upper clamp will allow the 2005/6 ignition lock
- the 2009+ upper clamp might also make using their stock damper a possibility...?
here's the long one.
- the 2009 forks are ~7/16" shorter. So to maintain the ride height these are not going to stick out of the upper triple clamp nearly as much if you use the 2005/6 upper clamp like I did. The 2009+ upper triple is flat...not offset up like the 2005/6 (which will also impact clip-on position) The stock spec 2005/6 fork stick out is ~1/4"...so if you also run a 120/70 front tire and compensate for that height, you can get the stock rake angle/trail back and still have some stick out of the forks....this will vary slightly based on your brand/model of tire.
I haven't done a road test yet....Memorial Day it will be at Road America...so, we'll see how it goes then if not sooner.
Here's a summary.
