Okay so I have a ZX6R 2001 now it turns over elrond but when he gets up to about 150 degrees if you're not constantly on the throttle when it goes to idle it will die...... now stayed on the gas not letting the RPMs drop below 2000 it will heat up to 2 30 degrees in the fan kicks on at which point if I let the RPM drop even a little it will die right out and usually turns over immediately I can turn it back on
