HI all... i just recently picked up a 97 ZX-7R. The bike has 6500 miles on it and was crashed in the front end. I replaced the steering stem beacause that is all that seemed broken. Bike obviously ran before the accident but that was two years ago.
I replaced the Gas with fresh 93 before starting it.
The problem I'm having is that the bike cranks HARD, but just won't start. I think I have gas, its coming out of an overflow??? on the top of the motor, im not sure exactly what that piece does though.
I have spark... checked with a spark tester, and theres no reason i shouldn't have compression, bike ran fine before the accident, no engine components were damaged.
My thoughts are that the jets in the carbs are stuck.... not allowing gas into where it should go. I orignally thought I had flooded out the cylinders, so i pulled all the plugs and free wheeled the motor.... gas only came out of the number 1 cylinder.
Thats all I can think of, anyone else have opinions? How hard is it to remove the carb assembly on these bikes?
THanks,
Gregg
THanks,
Gregg
