i noticed that my bracket that holds my exhaust has alot of space around the slip on and i looked at the nut to see if it needed tighten
but it dosent look like it will go tighter.
now do u think from the wheelies and the stoppies i do could of made it lose.
and if so how do i fix it ,i mean it still holds the slip on but the bracket isnt right aginst the can it has like 2 inchs of space around it so u could wiggle the can back and forth and i dont think it should be that way and help would be great.
please reply..
keep one wheel up (you choose which one)
are you trying to use the stock bracket on an aftermarket can?? maybe that's your problem. Most aftermarket slip-ons usually come with a new bracket. It might be possible that they gave you the wrong bracket for your can. But it definitely should not be wiggling..it should sit tight.
no its the factory can and factory bracket i just dont know how to tighten it because like i said the bolt looks like it wonlt get any tighter
