Can I use the brake cleaner spray directly on the discs and calipers without disassemble? How much should I use and do I need to wipe it off the disc?
Read the instructions before buying, most brake cleaners evaporate without leaving a trace - any residue at all, so yes, you can. You should spray some cleaner on a cloth and give the rotors a good wipe to eliminate glazing.
If it is a high pressure, strong spray, you will clean about 80% of the parts but it will be hard to reach the pistons and the are around them which is the most important.
You can clean everything 100% with soapy water when disassembled.
