900 miles ago (I keep records) my mechanic installed Galfer SS front lines and ASV levers. I drove around and had some brake fade so he bleed the entire system going through two reservoirs only producing tiny bubbles. A week later after riding around, hitting bumps, getting the fluid hot on some longer rides it started up again as expected so we did the same thing and very tiny bubbles if any. Last week it started again so I decided to get some speed bleeders, even for the MC, which I installed and instead of using the reg Silkolene stuff I went to the fancy Motul RBF600 factory line to see if it would improve with the higher heat resistance. Took it out for a short 30 test ride today and almost zero fade but on the last two stop signs before I hit my house more brake fade so while it was hot I bleed the entire system and NO bubbles anywhere! What the hell am I supposed to do? Bike only has 11K miles so I doubt it's the MC and even then how would I test it other than seeing if bubbles were coming out? I only mention the levers because before the new lines/levers it all worked great. My wife's new 2011 250R doesn't have these issues when I use it as the control in my experiment...
Thanks for any ideas.
