Hey guys, my brake light is always on high, as if I were riding my brake... I may have pinched something when I put on my exhaust but I do not see anything out of place. Does anyone have a picture of where the wires that control this are located? Or any ideas why else this might be happening? Thanks a lot y'all.
if u have a cleaer alternative it may be defective. the second one i had was defective it was on permanate on.
the place peice that is on the rear set needs to be re adjusted from when u took it off and also you could have put the spring upside down when re instaling it
NO YOU'RE F*CKED! Talkin' jazz bout my taillight...
Thanks a lot guys I'll get on this, been gone the weekend -- appreciate the help.
Discussion Starter · #7 ·
Agh ok well when I went to check that out I found out it's cause the damn motowerkz exhaust is rubbing it and won't let it recoil... will have to figure this out... Thanks though guys I thought it was some kind of wiring issue.
