i have an 07 zx10r and my brake light does not engage when i hit front or back brake lever . i switched the rear brake light switch out still nothing . any help would be great .thanks
If you're saying doesn't work for the front or back then I would say its not the switches.
Do your running lights work? If you haven't already I would check the connections to the tail light to make sure their tight and not damaged.
My running lights are on I have looked at the connection it seems good . I get no dimming or anything when I pull the brake levers
Check your fuses. Also, check the rear brake light bulb. One of the filaments may be burnt out.
