Ok so it used to work fine, now- my tail light is on when running, integrated turn signals work fine, BUT when I hit brakes, either front or rear, it doesn't brighted up. Thoughts??? Any help would be greatly appreciated, I dont really feel like getting hit from behind, that would kinda suck...thanks!! All connectors are connected together BTW
Check the light bulb. It has 2 filaments in it. One of them (for the brake light) probably burnt.
Thanks for the reply, however its a multi led light. It doesn't have a standard brake light bulb. As a check, I replaced it with the stock tail light, same result.
Pursebully
Do you know what brand the tail light is? I've seen several have internal board problems, especially the cheaper ones. If you have a multimeter or test light, you can unplug the connector and verify that you're getting a brake light signal to the connector. If you are, then you'll need to replace the tail light.
