RSV is where I got my rear sets from they arrived a little later than first estimated but they’re a good honest vendor. Quality is pretty good.
In order to use these(they make a 100mm version as well)
You’ll need a pair of callipers, and I recommend changing the master cylinder to match callipers as well to retain stock levels of performance.
You can often find sets from older sport bikes at wreckers on line with master, lines and callipers included
Good callipers to upgrade to are anything from japanese sport bikes zx10, r1 gsxr, etc
They also make an upside down hanger for brembo racing rear caliper so if you want to match front and back, you can
If you buy used it might be wise to factor in pads, seals/calliper rebuild kit as well.
rule of thumb
European bikes have 100mm radial callipers(spacing between the bolts. Japanese use 108 spacing. Stay away from the r1 six piston callipers they will only fit r1 forks.
you may also need to space the callipers out to fit the disks you have as all forks and callipers are a little different in that respect
if you need to space the callipers you may also need longer bolts to suit.
rule of thumb
