21 - 22 of 22 Posts
Brembo sells a kit to fit oversize rotors on a bike with radial calipers, like putting 300mm rotors on a 03/04 636, but its something like $60. All you need are four 10x70mm bolts in 1.5 pitch, finer thread than a typical 10mm bolt, and four 10mm thick spacers with a 10mm hole in the center. I made mine out of 7/8 diameter aluminum rod. I have access to a lathe at work, but if you don't they shouldn't cost very much to have made, they are a very simple piece. The bolts were a little over a dollar a piece at the local hardware store.
The bolts are 1.25 pitch, NOT 1.5.
21 - 22 of 22 Posts
