1 - 13 of 13 Posts
Time to flush her out.
have some white stuff in the bottom of mine i guess i should do the same...is it possible to do without taking the fairings off?
Make sure ur using distilled water. Tap water has all kinds of sh*t in it that wreaks havoc on ur cooling system. Engine Ice is the best, it's about $15 for a bottle big enough to fill ur system. Water Wetter also works well, but again make sure ur adding it to distilled water.
how do u go about draining the coolant is there a drain plug? ive search with no luck, some ppl say there isa drain plug some say there isn't some use vacuum lines to take it out, let me know....also if there is a drain hole could someone show a pic or somthing of it..
DEATH TO THE ISA!!!
yes, you have to remove your fairings....check your PM
if the brown/white stuff is like a gritty texture its fine. all kwaks have this. nothing to worry about.
Discussion Starter #13
I finally found more topics on in using the search and mine looks like the casting sand thats supposed to be normal.
1 - 13 of 13 Posts
