1 - 2 of 2 Posts
Looking for some help. I have and 05 Brute 650 and the front back are locked up. I have bled the system 3 times with new fluid and everything is good until you use the brakes a few times and then the brake lever is so hard you can't squeeze it. You can't move the bike when in Neutral as the brakes are that tight. Any help?
Sounds like the pistons are sticking in the calipers.
1 - 2 of 2 Posts
