can't find it anywhere on the interwebs...if I'm missing it please link me...or if someone would be so kind to go measure the circumference of their stock tires I would appreciate it. Thanks!
I found that the diameter is 630mm for a 180/55-17 BT-016
630mm x (pi) = 1979.2mm (overall circumference)
I think this is correct..? hope this helps.. what do you need this for anyway?
:Bowdown::Bowdown: would you mind getting the front wheel as well? This is for calculating ride height between brands of tires.
hey, the front wheel diameter is 602mm so the circumference should be 1891.2mm
on the Bridgestone website the diameter along with some other dimensions are mentioned but not the overall circumference.. unless I missed that also!
