im posting this question for a friend and for my own personal knowledge
so my friend has a 2011 250r
mods:
3 washers under each needle
MGP Growler slip-on
K&N air filter
snorkel removed
cali emission removed, holes plugged where needed
clean air system removed
bike started up fine multiple times w/o choke
but it only ran about 1 block and died
symptoms:
bike will not start w/o choke about halfway or full, idle at or less than 2k rpm
bike will die with slightest throttle input with choke below halfway
seems like carbs were not delivering correct air/fuel mixture
so we fiddled around with the idle knob
it would run alright at certain parts as we back off the choke, then it would die
we thought there might be a vacuum leak where we plugged, so we double check and all plugs were good
i thought, it was the idle mixture screws, too damn hard to get to
so we ended up putting the emission back on, clean air system, snorkel, and going back to 2 washers underneath each needle
and bike ran great.....
so what are we missing or messing up on?
mods:
MGP Growler slip-on
K&N air filter
snorkel removed
symptoms:
