1 - 9 of 9 Posts
How would i check and see if my cam chain skipped a tooth. I have been having a problem for months and nothing i have tried worked. Thanks for the help.
this is pretty unlikely unless the cam chain tensioner failed....even then....I've had a couple go bad on different bikes and neither jumped the cam.
you'll have to get down to the cam's...ie: under the valve cover.
I'm sure there's instructions on doing a valve adjustment somewhere in the forum...you're basically going through most all those motions.
That Fighter Guy
The first thing I want to know is what these "problems" you've been having are. Gotta know what the symptoms are before you treat the illness.
Ok well heres the summary. My bike runs great under 5 grand, but from 5-8k there is nothing, then it picks up but it wont rev above like 12k. Each gear is progressively worse until i cant get above 9k in 6th gear. Also I get less than 30 mpg when i ride it hard. So basically no high rpms at all.
highly unlikely you cam chain skipped a tooth
if it did your bike wouldnt be running right at any rpms
not to mention the valves would open/close at the wrong time and might hit the piston
check your throttle cable
might be loose and just needs a bit of tightening to get the throttle plate to open up
but im no mechanic......yet ;)
i thought it was a fuel issue too. I changed all 8 injectors and the fuel pump. All thats left is the fuel lines. Another interesting thing is I can very strongly smell gas when i get on it hard. Idk if thats normal or not.
1 - 9 of 9 Posts
