That's the connection for the Clutch switch.
From what I can see someone has swapped the Clutch perch as the switch connection doesn't look like the right one.
+1 on clutch switch.
Starter doesn't engage if the bike is in gear? Get one of these (click link below) plug it in there (the pic of the empty plug you have) and problem solved.
2008 Kawasaki zx6r ninja
Yep clutch switch.. I bypassed mine when it went bad. Tried cleaning the connections without any success. You can just bridge the connections to bypass the clutch switch..
