Aircraft stripper burns paint off metal like nobody’s business. It’s also dangerously corrosive and combustible, but hopefully that’s self-evident. I stripped an ’85 600R tank in no time with that crap some years ago.
Question: once the wheels are polished, are they sealed? Aluminum and alloys gradually form very thin layers of aluminum oxide (corrosion or protection, depending on how you look at things) by exposure to the atmosphere. The oxidation inhibits additional corrosion, but still slowly builds up over time. Apparently acidity and alkalinity also play a part, making me wonder what various cleaning products do to the metal surface.
Whatever paints and primers they use on the wheels inhibit corrosion by shielding the raw metal, as you might guess, as does anodizing (creation of an artificial aluminum oxide coating on aluminum). Aluminum tends to “pit” (corrode) when the aluminum oxide coating is disturbed. Look at older aluminum car wheels for an example.
I do not know what aluminum alloy ZX-6R wheels use. Is there a final treatment, do they naturally resist corrosion well, or what?
-=DRB=-
