1 - 9 of 9 Posts
Not sure what I did, but I can't get it to start.
Changes after last start:
removed front wheels
removed and reinstall rear wheel
that was it
I've also checked all the fuse and they are good. it looks like the bike thinks the battery was disconnected, but didn't. the clock started at 1:00
here is a vid
Where is hoser??
Unhook and clean, then reattach your battery cables. It sounds like they are causing the popping sound.
--David
Sounds like the battery is dead. As soon as you hit the starter it looks like the low voltage resets the ECU. Maybe try charging the battery or replacing it.
it was the battery, charge it with a tender for couple of hours, fires right up! thanks all
1 - 9 of 9 Posts
