help it seem to be cliped onto the u shaped part i took out all the screws. I need to remove it to change the oil
On my bike, there are three plastic rivet type things that snap into the U shaped fairing under the bike. After you take out all the fairing bolts, you should be able to just pull on the fairing to get it off.
are you sure the bottom screw that holds the v-shaped fairing is out? you can unscrew the other side of that fairng too. it will make instalation easier.
i took off the right faring.
