1 - 2 of 2 Posts
any idea`s what more i can do to stop my carbs icing up on cold damp mornings,it usually happens when trying to accelerate after a junction,it just bogs down !
it has no fairing,and the frame holes are blocked off,i have also taped up part of the radiator !
Some European models had coolant routed around the carbs to prevent carb icing. It is normally only a problem in high humidity conditions when the temperature is just above freezing and at low trottle settings.
I have a factory manual for the '95-'97 and it shows this feature. It also shows an inline filter or some sort. Could it be the filter is clogged?
1 - 2 of 2 Posts
