I have an 07 ZZR600, I have a K&N filter and just install a two brothers bolt on and at the same time did the carb shim.
It seems like the bike has lost some power in the low end in first gear since the change. When I start from a stop it seems a bit sluggish. I though the carb shim was supposed to improve the bikes performance.
Any ideas/suggestions?:confused:
I would go back and check your work. Check and make sure all the vac. hoses are conected right. Make sure you didn't loose the little o-ring that seals the vac. port in each needle cover.
