-1 Front +2 Rear
The response on the bike, now, is incredible. Taking off was not as excessive as I previously imagined. Taking off, I expected the front end to lift as I gave it more and more gas, but it did not, even when I gave it about 7,000rpms.
My speedo is off by 16% now. I had someone stay at 45 and then 50 mph. Then followed them, and my speedo showed 52mph and 58mph.
My front sprocket was from www.drivesystemsusa.com. Standard 15T Drive Systems sprocket.
My rear sprocket was also from them. It is a Supersprox Stealth 45T Sprocket.
The chain is the RK 520 Green DID O-ring Racing Chain.
edit:
Also, my top speed drop considerably, I used to be able to pull 12k rpm, 5th gear, 154mph. Now, 6th gear, 10k rpm, 134mph. All on the inaccurate speedo. http://www.sportrider.com/tech/146_0008_gearing/index.html
Pictures!
edit:
Pictures!
