1 - 18 of 18 Posts
Anyone else experiance this and is it normal?
I hear it on my 03 as well. It seems to be the norm.
mine does it under hard braking, I read somewhere that its the chain moving up and down ????
Mine clicks as well, usually under hard braking. Also, have any of you experienced the bike popping out of gear? I could have sworn that once or twice, when I was slowing down suddenly, I'd hear a click sound, and it felt like the bike changed gears. I was in 3rd, and when I geared down, only one click to first. Maybe I'm crazy...I usually only hear the clicking under hard braking, when going over a slight bump in the road.
"I usually only hear the clicking under hard braking, when going over a slight bump in the road."
steering stem bearings my friend....
or make sure your brake calipers are tight, maybe the are loose....
Guys
If you remember I posted a while back[zx6r.com]about my bike
being repaired after an off,Aust$2700, and on the ride home the front calipers fell off. There was a clicking sound everytime I used the brakes cause the bolts were only hand tight ![xx(] so please check all the brake bolts as you dont need to have what happened to me happen to you..
mfzx6r [}:)]
that musta been slightly freaky having no front brakes all of a sudden[:0]
did ya know they came off while u were riding?
I had that uneasy feeling they might be just hanging there.
Stopped by using the rear. Both calipers just hanging there.[B)] What would have happened if they got caught in the wheel ??
mfzx6r
I hear the clicking when I pull away from a stop light. 1 loud click then consecutive clicks but not as loud as the first. Does anyone think that this could be a gear problem? or could it be a chain problem? pleae someone help me cuz Im very concerned. dont have a car. bike only mod of transport. thanks guys.
:D
I have the same problem!! ;)
Does your bike go faster and faster after every click mine does! :D
:D
I seem to have this problem even when I had my Suzuki.....after every click, everything in my mirrors just shrinks to nothing.[:eek:)]
Originally posted by alphasparky
I seem to get a little click from somewhere in the front end when I give the front brake a quick jab, hmmmmm
mine does it too every RARE once in a while (I've only heard it maybe 3 times)
1 - 18 of 18 Posts
