1 - 2 of 2 Posts
It seems no matter how i adjust my clutch cable, the clutch is never fully disengaged. I can make it so the clutch engages close to the bar or as far out as possible and when i pull in the clutch lever, the bike is still pushing. Is there an internal adjustment somewhere that i can adjust? It did this with the stock clutch plates, which i replaced because the clutch was also slipping. It continues to do it with the new OEM plates i put in as well.
Dave
u can adjust the cable down by the clutch cover and also at the clutch handle, u want alittle free play at the handle bc if u apply to much force on the plates u will burn up clutch plates
1 - 2 of 2 Posts
