just installed new cluthes in my zx9r...it slips badly..i didn't notice the position of the "spring washers"..any help????
1. did you soak the friction plates in oil?
2. did your use a torque wrench to tighten things back down-correctly?
3. did you change your oil?
4. did you put the friction plates and steel plates in the right order?
5. (the biggy) did you readjust your clutch cable??
6. check the clutch release mechanism for correct operation
7. the last friction plate MUST... MUST be in the groove in the housing
let me know...
Discussion Starter #4
i need the torque specifications for the pressure plate....and also the placement of the spring washers...do they both go in with the first fiber plate...or one with the first and one with the last...other then this i have covered everything...thanks
