Okay so I just put in a new clutch kit in my 06 zx6r old one was burnt out got the barrnet performance kit, fist question is the 2 big O rings were not sent with my new kit online videos show how to put them in but I didn’t get them with my kit do they require them? Also after I put everything together I tightened my cable every way I could and the lever is still very loose any suggestions? I took the clutch completely apart 2 times and made sure everything was on right... stretched cable? It was fine before I took it apart
+1 The cable needs to be adjusted at both ends, especially if you have made major changes (like replacing a worn out clutch).
As far as the O rings, call the vendor you bought the clutch from and/or the manufacturer and ask them about it.
