1 - 13 of 13 Posts
the left hand engine cover is not the clutch cover. but if you're sure it's the clutch cover, i've done it before. last week. easy stuff. drain oil, disconnect the clutch cable, remove clutch shaft, unbolt clutch cover, install new one (with everything included) and gasket, reinsert clutch shaft, reconnect clutch cable, new oil/filter. you're good to go. need more help, pm me.
you would be better off just buying the carbon cover for it...thats what i did :)
edit: it comes with a cover for the other side as well
Just some fyi, if you leave the bike on the kick stand you do not have to drain the oil to remove the clutch cover as it will not lose much oil at all.
To replace the cover is very simple, just remove bolts and undo the clutch cable, pull the cover off and put the new one and put it all back together.
Discussion Starter · #9 ·
Where did you get the carbon covers from? I can't seem to find them anywhere
oppracing.com
yeah oppracing.com i believe i cant really remember i think it might have been on a group buy off this website though so do a search..if you can contact that same guy he will still probably give you a deal if you mention the site and the GB
i wanted one but heard that they were on back order.... not true?
not when i got mine a few months ago..
1 - 13 of 13 Posts
