1 - 2 of 2 Posts
i know my clutch is wearing but its slipping prettybad. when i get on it in any gear itll slip. ive tried adjusting my clutch lever becuase it was to tight but that didnt help. and when i adjust it down at the case itll work for alittle while then slip again. anyway to help this last longer. this slipping sucks when trying to ride:mad:
replacing the discs isnt too bad of a job. what kind of oil are you running? if youre running regular motor oil it might not have the right friction compound and that could be causing your slipping. otherwise your clutch is shot and you just gotta swap it out.
1 - 2 of 2 Posts
