So I just replaced both the Rectifier and stator. Everything was fine for about a week. I wake up this morning turn on my motorcycle but the headlights didn’t turn on, I thought that was very weird so I turned it off. I try to turn it back on and nothing. I just hear a tiny clicking noise but nothing. I’ve replaced the rectifier before but the same thing happened. Now that I replaced both it continues to happen. The battery is good.
after your replacements, did you actually test stator and RR outputs for adequate voltage specs?
Beyond battery load test.....+ and - terminals tight and clean?
Check the ground connection to the chassis as well. If there is corrosion, it could cause issues like this.
