Hi All! I noticed a coolant leak in the garage on my 6R yesterday. I checked and noticed the leak coming out of the top of the radiator hose on the right side. I tried tightening the clamp but it was still leaking. What do you guys think would cause this? Any help/suggestions is much appreciated :thumbup: Thanks all!
Discussion Starter #2
Any ideas/help guys? :( Thanks again!
That Fighter Guy
Something like that most likely is caused by age, man. Order a new one; I'm sure they're not terribly expensive.
  • Like
Reactions: badassjake
Discussion Starter #4
I'll try that route, man and give an update. Thanks bud :thumbup:
My 6r was leaking coolant as well. I first noticed the leak on the lower left side around the water/oil pump, but eventually chased it down to the upper hose connected to the thermostat going to the radiator. Since I had to drain the coolant I decided to go ahead change all the hoses at once.
I'll try that route, man and give an update. Thanks bud 👍
Any update?? Im having a similar problem. Except i replaced the thermostat and now it isnt leaking from the house but through the top of the radiator cap. Thought it was air bubbles but i flushed it and got the bubbles out. I am sooo confused and lost!!! Just wanna ride
