hey
got to work the other day and the thermostat had licked much above the cold marker on my 96 zx6r. but there was an awful lot of heat coming off the engine still. i touched the side cover and it burnt my hand so what do you thinks going wrong. blockage? stuffed pump? something else?
glenn
Is it doing something it hasn't been. The '95-'97 run very cold. I usually keep half my radiator blocked even in the summer and I live in South Texas where the temperature regularly get over 100 F.
I have a feeling your coolant is low. If the coolant isn't touching the sensor the sensor will show a low temp reading, but obviously the bike was hot cause you burnt yourself. Or your sensor is malfunctioning...get it looked at..
