Originally posted by CdnNinjaZX6R
drilling a circular hole should right at the end of the crack should prevent it from spreading.
If you can remove the fairing and line up the crack, use a ABS plastic welding compound (its a chemical you can buy) that will fuse the plastic, basically as good as new.
-=Welcome To Canada=-
2002 Green 6R
1986 Gixxer 7/11
