so it’s just not getting any fuel from the carbs to the engine, the carbs them selfs are full of fuel. When I try to drain then fuel comes out. But nothing going into the Cylinders, I’ve cleaned the carbs 3x , I wanna remove that needle from the jets after I unscrew it but I’m not sure how to is it a c clip or something?Probably need to re-check everything you did on those carbs, all jets put back in the right places, especially the needle jets & needles. Did you take out the pilot screw plugs so you can remove & clean the pilot screws? Did you check float levels?
