1 - 2 of 2 Posts
Yet another innovative solution from Constructors Racing Group, the Arrow Mirrors are light, stylish and functional – the way aftermarket motorcycle mirrors should be. Each CRG Arrow mirror is made up of 28 individual parts and its aerodynamic styling gives a superior view of the road behind you. The patented mirror’s metal components are precision machined from 6061-T6 billet aluminum and assembled with high-quality stainless steel hardware. At 4.8oz on our scales, this is probably lighter than your bike’s OEM mirror. All machined components are anodized black to go with just about any modern motorcycle with 7/8” handlebars.
CRG Arrow Mirrors are not yet available on our website, so get in touch with MIKE through this forum, or by calling 866.931.6644 ext 804 to order. Is email more convenient? Feel free to send those to FORUM at RIDERSDISCOUNT dot COM and we’ll get back to you right away!
CRG Arrow Mirrors are sold individually.
Arrow Mirrors are adjustable directly behind the reflective element itself, as well as on the post that holds it on your motorcycle’s handlebar.
They can be mounted directly to the handlebars and only need 10mm of space for the clamp. If you do not want to move your controls inward to make room you can opt for the CRG Bar-End Adapters.
Discussion Starter #2
Even though the CRG Arrow Bar-End Mirrors only need 10mm of space on the bar for the clamps to fit, it is even easier to mount them using the internal adapters. CRG Internal Bar-End Adapters are adjustable and will mount inside the ends of most bars. The minimum internal diameter that they will fit is 12mm, while the maximum is 19mm.
1 - 2 of 2 Posts
