1 - 13 of 13 Posts
How do I do this? Do the fuel pumps require the full 12 volts? I hooked up the pump to a 12v spower source, it pumped. I hooked it up to a 6v source, nothing. Checked the voltage it is recieving incircuit... 8.4 volts. Relay has a resistance ov 1 ohm I believe... checked with an ohmmeter. I didnt know it was supposed to have resistance... or is it? please help!
Rob
Chances are you can go to a parts store and find one that does the exact same thing for a bit cheaper.
BC.
You should, unless you removed it yourself.
Follow the fuel line from the tank to the carbs.
BC.
Discussion Starter #9
so how do I check this thing with a meter or something? What kinda readings should I get from it in termms of resistance? Thanks
I took the fuel pump off. I was just letting you know it will work without one if you had to run the bike. I dont run one for stunts.
It will work without one, you just can't use the bottom part of the tank, and wind up not having any reserve....
Whatever floats your boat.
BC.
Discussion Starter #13
bringin this back up for guy asking about the relay... i changed the relay and it started only cuz there was fuel in the carbs... then it died again cuz it wasnt getting any more fuel
1 - 13 of 13 Posts
