Originally posted by pcracks25
wheelies are so easy.....best way to learn is at nite on the highway on a straight...get in second gear doing about 45-50 and dont hold the bars for dear life...rev that bitch till like 12-14k and pop the clucth...think of it like pulling the trigger on a gun and watch it come up nice and easy.
I agree with the analogy of pulling the trigger on a gun, but I don't like your method of reving to 14k and "popping" the clutch. Maybe its just the way you described it. When I had my 636, I would rev to like 8-9K, use one finger to slightly pull in the clutch (just enough to allow it to slip) and simultaneously go WOT and let go of the clutch. It should pop right up, then let off the gas slightly to keep from looping.
At first your going to let off too much which will make the wheel come down, sometimes hard. I agree with what he said about not gripping too tight. If you come down with the handlebars crooked, it could cause a tank slapper. Use your arms like a damper.
Just keep practicing and you will get a feel for it.
Cover your brake, wear all your gear, and have fun.
