1 - 12 of 12 Posts
The 6R and 6RR say they have a "back-torque limited clutch". How does this differ from a slipper clutch, or are they the same?
Well, a slipper is something your wife throws at you. The back torque thing only comes after the slipper thing. [:I]
Does the ZX-6R have the slipper clutch or just the RR? The dealership I bought my bike from seemed to think that the RR did and the R did not...
The 636 has it also. The previuos models, 03-04 only the rr had it. Now we all do!!! yeehaa
Now that that is cleared up, I can feel free to hijack....
I was under the impression that a slipper clutch would allow the rider to dump the clutch at a higher speed than normal without causing the rear to lock up. My buddy with a new R6 dumps his clutch from 4th to 2nd gear at like 130mph, whereas I had considerable fishtailing downshifting from 3rd to 2nd at about 115mph (2nd goes to about 100mph at redline). Yes, this was on a track and yes, you should never just "dump" the clutch - but what gives? I must have left a 50 ft skidmark the last time I did this (not to mention the change of underwear needed).
-Chingon-
That why I kinda wonder about the 6R. Is ours just set really tight or something? Does anyone on here have a 6RR and had better results because I dont ever feel anything slippin...
i had an '04 636 right before I got myself an '05 and I can tell you that the slipper clutch is in fact there and working. i would have to be dead on with blipping the throttle everytime i downshifted in the '04 or else i'd get some twitching, but in the '05 i could literally bring it up to 5th and slam it down to 2nd with not much of a fuss. it's still a good idea to blip the throttle for the extra smoothness though.
Originally posted by GreenEnvy
Chingon, there are limits to how much it will slip, so in your case, you probably exceeded it.
While it does a good job of preventing this, if you are on the brakes hard, the back end will get light, and the wheel may lock anyway.
Aw, yes. I was on the brakes pretty hard so that would explain it. I guess even with all the go-fast goodies I still have to learn how to actually ride properly[:p]
1 - 12 of 12 Posts
