I want to get a cheap dirt bike to mess around on and my cousin has a 2000-2001 100cc kawasaki. i havent seen it but he says its in real good shape nothing wrong with it he hardly ever used it. He told me hed sell it to me for $800. Is that a good deal i don't really know what they go for.
The 2001 kx100 was around $3400 msrp when it came out. So I guess it depends on what condition it's in. Check around the net for some price comparisons. I found some good reviews on the net about that bike, just type in 2001 zx100 in your search, should bring up a bunch of info. Good luck! :)
2001 KX100 SPECIFICATIONS
Engine 2-stroke single w/KIPS
Displacement 99cc
Bore x Stroke 52.5 x 45.8mm
Cooling Liquid
Carburetion Keihin PWK28
Induction 2-petal reed valve
Compression ratio 9.6:1 (low speed) - 8.8:1 (high speed)
Ignition Digital CDI
Transmission 6-speed
Frame High-tensile steel perimeter design with subframe member
Rake/trail 27°/4.1 in.
Suspension type, front Inverted telescopic cartridge fork, 36mm
Suspension adjustments, front 18-way compression damping
Suspension type, rear UNI-TRAK® single shock system
Suspension adjustments, rear Preload, 4-way compression and 18-way rebound damping
Wheel travel, front 10.8 in.
Wheel travel 10.8 in.
Tire, front 70/100x19
Tire, rear 90/100x16
Brakes, front/rear Hydraulic disc
Overall length 75.2 in.
Overall width 28.9 in.
Overall height 43.5 in.
Ground Clearance 15.0 in.
Seat height 34.3 in.
Dry weight (claimed) 149.9 lbs.
Fuel capacity 1.5 gal.
Wheelbase 50.8 in.
M.S.R.P. (USA) $3,449
*Specifications subject to change.
