Protect your bike’s swingarm from damage in the event of a crash with axle adjuster block swingarm sliders from Driven Racing. These swingarm sliders not only help reduce, if not entirely eliminate – damage from a sliding type crash to your motorcycle’s swingarm, but they also add a trick appearance to your bike and make it easier to obtain proper chain tension when changing wheels. Driven Racing axle block sliders are precision machined from 6061-T6 billet aluminum to tighter tolerances than the OEM chain adjuster blocks. It is due to this quality machining that there is less play between the axle and the adjustment blocks when tightening the axle bolt after rear wheel installation. Barring a sprocket change, your axle blocks are less likely to require adjustment to maintain the same chain tension when changing out wheels.
Driven Axle Block Sliders are currently available in your choice of Black, Blue and Red.
These are not yet available on our website, but you can order a set of your own by calling MIKE at 866.931.6644 ext 804. Is email more convenient? Feel free to send those to FORUM at RIDERSDISCOUNT dot COM and we’ll get back to you right away!
Driven Axle Block Sliders are shown here in blue.
The precision machining gives them a better fit with less play than OEM chain adjuster blocks.
