It mentions in my manual to move the rear tire and then check the chain slack, and that it should be 35-40mm. If I move the tire forward, doesn't that take up all of the slack, in which case it will always be less than 40mm no matter how loose the chain is?
It seems like this method would measure the amount of tension you are holding on the rear tire as opposed to how much slack you have. Am I reading it wrong, or am I just being stupid?
