1 - 2 of 2 Posts
Anyone have input/past experiences/tips on how to install dyna coils??
Basically i have already installed them but something sounds wrong..
The bike runs, and they are in th right order.
Do you think there is a difference in the coil input which wire goes where (there are two for each coil) Would it make a difference??
Any feedback appreciated
start and warm it up and check the exhaust down pipes for temperature......spit cover your pointer finger and quickly tap the pipe, the spit should flash dry and won't burn your finger......like mom's do when they test to see if the iron is hot enough.....repeat for each pipe.....if they are all burning the same you will know.....if not it will be obvious as the spit won't flash dry....
does that make any sense to you???....LOL..............
did you replace anything else or alter anything when you did the coil swap?....
the wires usually don't matter but cyou can try switching them to see if it does to see if there might be a weak connection or bad wire.
1 - 2 of 2 Posts
