Ok, I just got up from a nice nap after a 10 hour journey that started at 6AM [
)] to get my bike dyno tuned by world renowned tuner, Mike Velasco.
As promised earlier last week, I've attached my dyno chart before and after today's tune. I have also included an older chart prior to the Kit ECU install. The skinny... 119.9 after tune, 114.9 before and 110.5 prior to ECU install.
Here some notes of the set ups so please read carefully before you decide to ask questions, hah:
- I have noted all related performance mods so unless otherwise noted, she's stock.
- Run on Chevron 92 pump gas.
- Sep 16th - Kit ECU, PC3 (zero map on base run and custom map on final), Akra slip on. Dyno numbers in STD.
- May 27th - PC3 (Tweakmon's map), Akra slip on, wire mod. Dyno numbers in SAE. Note that a stock zx6r, same year, same colour even posted 105 about 2 hours earlier. Different dyno, different day from above...
- Regarding SAE and STD numbers. Yes, I know there is a difference. Bear in mind that Seattle and Vancouver are both in the same region, same elevation, both day's temp and humidity were very similar (I checked).
My subjective thoughts? The Kit ECU rocks (even for a 636)! The power difference is noticeable, power delivery is immediate and the redline increase of 1000 rpm is pretty insane in comparison to my previous set up. That said, the throttle response was a little rough/abrupt in spots and the engine ran lumpy at times as it was rich on the bottom and lean up top, generally speaking. With the custom tune, the throttle response is super smooth and all the lumpiness is gone. The bike is running so smooth now that the extra ponies is very deceiving as you'll realize you've hit warp factor 9 but didn't know how you got there. Don't get me wrong here, the motor is still angry sounding and buzzy (hey, it's a Kawi) but the power delivery feels much more focused.
In conclusion, to get the most out of your Kit ECU, you should get a custom tune done as 5 HP up top and an increase in power all around is pretty good for my $250. Am I happy I bought the Kit ECU? Heck ya, but I'm even more happy cause I picked it up for >$300 used and now I'm running my current set up as close to it's fullest potential as I can.
Mike was extremely pleased with the tune job. We talked about different ways of getting more HP such as running race gas, more kit parts, full exhaust, etc but quite honestly I don’t need any more power. I'm just a street rider with a few track days lined up for next season. At this point, my money is going to be better spent on upgraded suspension and track dayz!
Wow... I typed way more than I intended. Sorry for the long read. One last thing then... I can't say enough about Mike Velasco. He's a very personable guy, loves his work and let's you get involved and observe the whole tuning process. Heck, he even had me tear down my bike for him (in my leathers no less) in order to get it ready for the big job! For those who are interested, Mike works out of The Brothers Powersports shop in Bremerton, WA. He's got a ton of credentials which I won't go too much into but names like Freddie Spencer, Mike Baldwin and many others are included in there and he continues to tune and prep for AMA racers.
Cheers - Stephen [^]
