okay so i finally got the bike back together, and tried jumping it. Ill turn the key to the on position and everything lights up like it should and the fuel pump kicks on to prime. I jumped it a couple times. one time I rode it down the street, and came back. shut it off, and tried jumping it again like an hour later and no guages or anything, even lights and starter didnt turn on. (there was a def good connection)
I bridge the solenoid and it fires right up. all guages and electronics work. i picked up a new solenoid and checked all fuses on the bike, main off the solenoid and then the ones under the tail.
If i tried to jump it, i would turn the key, nothign lights up, no brakes or anything, no priming, and ill click the start button and nothing, as soon as i cross the solenoid so it starts, it runs turns on, all guages work, all lights, fuel pump, and even the starter button works, (i hear it engage)
I just put the new battery in today also and still does the same thing as if i was jumping it. weird eh? is there a revse way to have the solenoid? maybe thats what i did wrong?
What do you guys think? let m e know thanx
